Updated to php 8.1 and getting errors
Thread begun 2/16/2024 9:22 am by BillHobbs | Last modified 2/17/2024 9:20 am by Mags | 499 views | 1 replies |
BillHobbs
I've updated to php 8.1 and I'm systematically going through all the pages to find and fix errors. But, I came across one error that is making me scratch my head. Here is the error. It is in the index.php file I've uploaded. Any help is appreciated.
"01", "Feb"=>"02", "Mar"=>"03", "Apr"=>"04", "May"=>"05", "Jun"=>"06", "Jul"=>"07", "Aug"=>"08", "Sep"=>"09", "Oct"=>"10", "Nov"=>"11", "Dec"=>"12", ); $date_elements['m']=$Mtom[$date_elements['M']]; } // print_r($date_elements); // for testing $dummy_ts = mktime( $date_elements['m'], $date_elements['d'], $date_elements['Y'] ); return date( $date_format2, $dummy_ts ); } //Returning Last Day of any given month to help in exh. period and resolving the MMYY PO number equivelent. // Take an integer month and year and returns the date of the last day in MM/DD/YY format function lastDay($month, $year){ $lastDay; $longMonths = array(1,3,5,7,8,10,12); // Months that end in 31 $shortMonths = array(4,6,9,11); // Months that end in 30 if(in_array($month,$longMonths)) $lastDay=31; else if(in_array($month, $shortMonths)) $lastDay=30; else if($month==2){ // February, check for leap year if(date('L',mktime(0,0,0,1,1,$year))==1 ) $lastDay = 29; else $lastDay =28; } return date('Y-m-d',mktime(0,0,0,$month,$lastDay,$year)) . " 23:59:59"; } function firstDay($month, $year){ return date('Y-m-d',mktime(0,0,0,$month,01,$year)) . " 00:00:00"; } //Status Code Resolved function StatusCode_Resolved($sdcode) { $SDNames = array('SD1','SD2','SD3','SD4','SD5','SD16','SD7'); $SDLabels = array('Draft Order','Order Posted','Order Approved','Lab Recieved','Materials Delivered','Closed','Voided'); for($i = 0;$i < count($SDNames);$i++) { if($sdcode==$SDNames[$i]){ return $SDLabels[$i]; } else { return "Not Found"; } } } function ShortenText($text,$chars) { if(strlen($text) > ($chars -3)){ $text = $text." "; $text = substr($text,0,$chars); $text = substr($text,0,strrpos($text,' ')); $text = $text."..."; } return $text; } ?>
Mags
I'm guessing it's connected to your /includes/datefunctions.inc file. Have you tried renaming that file to datefunctions.php and including that? Also add error reporting to the top of your index.php file as that might give further information:
error_reporting(E_ALL);
