Ray built paypal listener page insert doesn't work anymore code. Does anything look wrong?
Thread begun 2/14/2024 11:10 am by JBWebWorks | Last modified 2/16/2024 7:43 am by JBWebWorks | 1788 views | 7 replies |
JBWebWorks
<?php require_once('Connections/connsqli.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
require "paypal_integration_class/paypal.class.php";
require "config.php";
$p = new paypal_class;
$p->paypal_url = $payPalURL;
if ($p->validate_ipn()) {
if($p->ipn_data['payment_status']=='Completed')
$amount = $p->ipn_data['mc_gross'] - $p->ipn_data['mc_fee'];
if (true) {
$InsertQuery = new WA_MySQLi_Query($connsqli);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "paypal_transactions";
$InsertQuery->bindColumn("transaction_ID", "s", "".$p->ipn_data['txn_id']."", "WA_DEFAULT");
$InsertQuery->bindColumn("first_name", "s", "".$p->ipn_data['first_name']."", "WA_DEFAULT");
$InsertQuery->bindColumn("last_name", "s", "".$p->ipn_data['last_name']."", "WA_DEFAULT");
$InsertQuery->bindColumn("email1", "s", "".$p->ipn_data['payer_email']."", "WA_DEFAULT");
$InsertQuery->bindColumn("address1", "s", "".$p->ipn_data['address1']."", "WA_DEFAULT");
$InsertQuery->bindColumn("address2", "s", "".$p->ipn_data['address2']."", "WA_DEFAULT");
$InsertQuery->bindColumn("city", "s", "".$p->ipn_data['city']."", "WA_DEFAULT");
$InsertQuery->bindColumn("state", "s", "".$p->ipn_data['state']."", "WA_DEFAULT");
$InsertQuery->bindColumn("zip", "s", "".$p->ipn_data['zip']."", "WA_DEFAULT");
$InsertQuery->bindColumn("amount", "d", "".$amount."", "WA_DEFAULT");
$InsertQuery->bindColumn("item_name", "s", "".$p->ipn_data['item_name']."", "WA_DEFAULT");
$InsertQuery->bindColumn("quantity", "i", "".$p->ipn_data['quantity']."", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_gross", "s", "".$p->ipn_data['mc_gross']."", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_fee", "i", "".$p->ipn_data['payment_fee']."", "WA_DEFAULT");
$InsertQuery->bindColumn("special_requests", "s", "".$p->ipn_data['option_selection1']."", "WA_DEFAULT");
$InsertQuery->bindColumn("original_request", "s", "".http_build_query($_POST)."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Mags
Did you try turning on error reporting? Add the following code to the very top of the page, then try to run your page and let me know what the error message is:
error_reporting(E_ALL);
JBWebWorks
nothing shows as this is all code on the page
JBWebWorks
one strange thing - I us e DW with webassist SQLI and when i click on server behaviors and click ok, it changes the code to this
?><?php require_once('Connections/connsqli.php'); ?>
if (true) {
$InsertQuery->bindColumn("transaction_ID", "i", "\".$p->ipn_data['txn_id'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("first_name", "s", "\".$p->ipn_data['first_name'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("last_name", "s", "\".$p->ipn_data['last_name'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("email1", "s", "\".$p->ipn_data['payer_email'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("address1", "s", "\".$p->ipn_data['address1'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("address2", "s", "\".$p->ipn_data['address2'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("city", "s", "\".$p->ipn_data['city'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("state", "s", "\".$p->ipn_data['state'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("zip", "s", "\".$p->ipn_data['zip'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("amount", "d", "\".$amount.\"", "WA_DEFAULT");
$InsertQuery->bindColumn("item_name", "s", "\".$p->ipn_data['item_name'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("quantity", "i", "\".$p->ipn_data['quantity'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_gross", "s", "\".$p->ipn_data['mc_gross'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_fee", "i", "\".$p->ipn_data['payment_fee'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("special_requests", "s", "\".$p->ipn_data['option_selection1'].\"", "WA_DEFAULT");
$InsertQuery->bindColumn("original_request", "s", "\".http_build_query($_POST).\"", "WA_DEFAULT");
$InsertGoTo = "";
it adds the back slashes
Mags
If the page was built a while ago and you now have a newer version of DataAssist installed, chances are it will make some updates in the code if you open and re-save the server behavior. Not sure what the significance of the backslash is though, or why it would be added. You could try removing them manually. There certainly doesn't look to be any errors in the code. I see it's a page that runs the insert behavior on page load, so with error reporting on I would expect it to show an error when you load the page if it doesn't write to the database.
Has your server upgraded its PHP version recently? One thing you could try - where single quotes have been used (i.e. ['txn_id']) try changing to double quotes (i.e. ["txn_id"] - I'm not sure if this will make any difference but I've had a few issues when upgrading to PHP8 where I've had to change single to double quotes or vice-versa.
JBWebWorks
Thanks, I will try that.
It didn’t work so I found this code and it does the insert but not correct data because PayPal doesn’t validate. It gives errors 301 or 302. Any suggestions?
// STEP 1: Read POST data
// reading posted data from directly from $_POST causes serialization
// issues with array data in POST
// reading raw POST data from input stream instead.
$raw_post_data = file_get_contents('php://input');
$raw_post_array = explode('&', $raw_post_data);
$myPost = array();
foreach ($raw_post_array as $keyval) {
$keyval = explode ('=', $keyval);
if (count($keyval) == 2)
$myPost[$keyval[0]] = urldecode($keyval[1]);
// read the post from PayPal system and add 'cmd'
$req = 'cmd=_notify-validate';
if(function_exists('get_magic_quotes_gpc')) {
$get_magic_quotes_exists = true;
foreach ($myPost as $key => $value) {
if($get_magic_quotes_exists == true && get_magic_quotes_gpc() == 1) {
$value = urlencode(stripslashes($value));
} else {
$value = urlencode($value);
$req .= "&$key=$value";
// STEP 2: Post IPN data back to paypal to validate
$ch = curl_init('https://ipnpb.paypal.com/cgi-bin/webscr');
curl_setopt($ch, CURLOPT_HTTP_VERSION, CURL_HTTP_VERSION_1_1);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $req);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 1);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 2);
curl_setopt($ch, CURLOPT_FORBID_REUSE, 1);
curl_setopt($ch, CURLOPT_HTTPHEADER, array('Connection: Close'));
// In wamp like environments that do not come bundled with root authority certificates,
// please download 'cacert.pem' from "http://curl.haxx.se/docs/caextract.html" and set the directory path
// of the certificate as shown below.
// curl_setopt($ch, CURLOPT_CAINFO, dirname(__FILE__) . '/cacert.pem');
if( !($res = curl_exec($ch)) ) {
// error_log("Got " . curl_error($ch) . " when processing IPN data");
curl_close($ch);
exit;
curl_close($ch);
// STEP 3: Inspect IPN validation result and act accordingly
if (strcmp ($res, "VERIFIED") == 0) {
// check whether the payment_status is Completed
// check that txn_id has not been previously processed
// check that receiver_email is your Primary PayPal email
// check that payment_amount/payment_currency are correct
// process payment
// assign posted variables to local variables
$txn_id = $_POST['txn_id'];
$first_name = $_POST['first_name'];
$last_name = $_POST['last_name'];
$payer_email = $_POST['payer_email'];
$address_street = $_POST['address_street'];
$address_city = $_POST['address_city'];
$address_state = $_POST['address_state'];
$address_zip = $_POST['address_zip'];
$item_name = $_POST['item_name'];
$quantity = $_POST['quantity'];
$payment_amount = $_POST['mc_gross'];
$mc_fee = $_POST['mc_fee'];
$mc_shipping = $_POST['mc_shipping'];
// <---- HERE you can do your INSERT to the database
if (true) {
$InsertQuery->bindColumn("transaction_ID", "i", "txn_id", "WA_DEFAULT");
$InsertQuery->bindColumn("first_name", "s", "first_name", "WA_DEFAULT");
$InsertQuery->bindColumn("last_name", "s", "last_name", "WA_DEFAULT");
$InsertQuery->bindColumn("email1", "s", "payer_email", "WA_DEFAULT");
$InsertQuery->bindColumn("address_street", "s", "address_street", "WA_DEFAULT");
$InsertQuery->bindColumn("city", "s", "address_city", "WA_DEFAULT");
$InsertQuery->bindColumn("state", "s", "address_state", "WA_DEFAULT");
$InsertQuery->bindColumn("zip", "s", "address_zip", "WA_DEFAULT");
$InsertQuery->bindColumn("item_name", "s", "item_name", "WA_DEFAULT");
$InsertQuery->bindColumn("quantity", "s", "quantity", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_gross", "s", "mc_gross", "WA_DEFAULT");
$InsertQuery->bindColumn("mc_shipping", "s", "mc_shipping", "WA_DEFAULT");
$InsertQuery->bindColumn("payment_fee", "s", "mc_fee", "WA_DEFAULT");
$InsertGoTo = "";
} else if (strcmp ($res, "INVALID") == 0) {
// log for manual investigation
Mags
Sorry, I don't really know anything about Paypal integration. Errors 301 and 302 are usually redirect errors though - 301 is permanent and 302 is temporary.
JBWebWorks
I found (I think) that when the redirect is to https://paypal.com/cgi-bin/webscr the error is 301 permanently moved
and when the redirect is to https://ipnpb.paypal.com/cgi-bin/webscr the error is 302 temporarily moved
i don't know what that means or how to fix?
