Update page not uploading file and putting in database
Thread begun 9/24/2009 5:30 am by dave315749 | Last modified 9/24/2009 11:41 am by Jason Byrnes | 2599 views | 3 replies |
dave315749
Having a little trouble with the using default filename and uploading a new file. I have read all of the instructions and tryed a few suggestions in the forum.
Here is the code
It is not uploading a image and not putting it in the database field.
what am i doing wrong?
tom92909Beta Tester
1st... Are these paths correct?
<?php require_once('../../Connections/wearyour.php'); ?>
<?php require_once("../../WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
The actual Upload isn't working? Is that correct? No files are getting saved to the images directory? Is the path correct for the images directory?
dave315749
Yes the paths are correct, and there are no files being uploaded to the directory... and nothing into the database.
the products insert page works... attached.
For image upload to function, the forms encoding type must be set to multipart/form-data
change the form tag:
<form action="products_Update.php?id=<?php echo(rawurlencode($row_WADAproducts['id'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
<form action="products_Update.php?id=<?php echo(rawurlencode($row_WADAproducts['id'])); ?>" method="post" enctype="multipart/form-data" name="WADAUpdateForm" id="WADAUpdateForm">
