Error in DataAssist wizard
Thread begun 9/23/2009 11:16 pm by Zulian | Last modified 10/28/2009 7:34 am by Ray Borduin | 13535 views | 38 replies |
Zulian
I have the following error after running data assist wizard for result page.
Fatal error: Class name must be a valid object or a string in C:\inetpub\wwwroot\resorts\admin\hotels_Results.php on line 27
below is the generated code.
<?php require_once('../Connections/connTravel.php'); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAhotels;
//Searchpage: hotels_Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if ((isset($_GET["Search_x"]) && $_GET["Search_x"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("hotel","S_hotel","AND","Includes",0);
$WADbSearch1->addComparisonFromList("star","S_star","AND","=",1);
$WADbSearch1->addComparisonFromList("country","S_country","AND","=",1);
$WADbSearch1->addComparisonFromList("atoll","S_atoll","AND","=",1);
$WADbSearch1->addComparisonFromEdit("pricerange","S_pricerange","AND","Includes",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_hotels_Results"]=$WADbSearch1->whereClause;
else {
$WADbSearch1 = new $WADbSearch1;
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_hotels_Results"]) && $_SESSION["WADbSearch1_hotels_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_hotels_Results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
//WA Database Search Include
require_once("../WADbSearch/HelperPHP.php");
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
Your code should have the following at line 2:
Zulian
I can see that two line down in line number 87
Dear
I can see those two line in line number 87, but I don't know how it got there too. I have already tried multiple times for few days with this table only. my previous tables worked fine, but now it's give error. Please help me
Thank you
Those lines must be at line 2, not line 87 to fix the error.
Zulian
Still giving this error
I am getting this error, also I am wondering why I am getting this error as code is generated by DATA ASSIST, we don't have to touch the code while we do it with Data Assist.
Fatal error: Class name must be a valid object or a string in C:\inetpub\wwwroot\resorts\admin\hotels_Results.php on line 31
CODE IS HERE
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
Zulian
Can someone help me to solve this issue???
Hi! I am stucked in the middle of a project with Data Assist. I am wasting few days with only one table, but still no luck with the above error.
I need someone to help me to solve this issue.
Thanks in advance.
Somehow in between your two posts this:
It looks like your database search code is on the page twice... did you run it multiple times on the same page without clearing the page? That might be the root of some of these problems... you may want to delete or clear the page and try again.
To simply fix the error replace:
with:
but it appears there may be more issues since it really shouldn't appear twice like it is in your second code example.
The code looks correct in the first one other than the missing include file, so I'm not sure what else might have changed which is why I would probably start over.
Somehow in between your two posts the code got changed....
with:
Which is what it was in your first post, but it appears there may be more issues since it really shouldn't appear twice like it is in your second code example.
The code itself, though doubled, looks correct in the first one other than the missing include file, so I'm not sure what else might have changed which is why I would probably start over.
Zulian
I will try as you asked!!!!
Dear Ray,
you are correct.... I have run it several times in few days. but I never noticed it as I have deleted all files everytime after I got a problem
I will check as you adviced.
Thank you
Zulian
Now it's a different error!!!!
Dear Ray,
now I getting the error below.
Fatal error: Cannot redeclare class WA_AltClassIterator in C:\inetpub\wwwroot\resorts\admin\hotels_Results.php on line 376
I need your advice on what to do if I am running one wizard several times due a mistake I made while generating my pages?
