File uploads
Thread begun 7/11/2023 12:28 pm by birdscreen398247 | Last modified 7/30/2023 7:16 am by Ray Borduin | 557 views | 1 replies |
birdscreen398247
File uploads
I am having trouble with an Upload Files behavior on a form.
This had been working, but all of a sudden it stopped. I recently moved the web site to a dedicated server, but I can‛t figure out how that may have impacted this code. The files are all in the same folders and the tables have not changed.
When I click Submit, if there is a file to upload, it hangs up and says this page is not working. No other error message displays, even though Debug is on.
If there are no files to upload, it saves the record, sends the email, and goes to the Thank You page as the code directs.
So the problem is with the upload code. Lines 102 to 232.
So what is wrong with the upload file procedures?
If the code worked on a previous site, then the issue isn't in the code. Probably a server setting.
Did you try a smaller file? It could be a post size restriction or a memory limit being hit.
It could be a folder permissions issue on the new server.
It could be a difference in php versions and some function being deprecated.
This is all hand coded and not using webassist extensions for the upload, so I'd need to do a premier support ticket in order to debug it with you in a screen sharing session. Give me a call and I can squeeze in an hour to figure this out for you.
