Is Data Bridge 2.3.5 compatible with PHP 8.2?
Thread begun 7/05/2023 7:04 am by Mike | Last modified 7/30/2023 7:03 am by Ray Borduin | 1729 views | 5 replies |
Mike
I noticed that the last update of Data Bridge was from 2021, so I wondered what problems I would encounter if I upgraded from (current) version 7.4.3 to 8.2.7 of PHP. Thank you.
There have been incremental updates to fix issues with more recent versions of php. You should be ok with php 8.2 if you reinstall the latest version of the extension.
Mike
Ok, I'll try to update in the next days.
Thanks!
Mike
Hi Ray,
I've tried on a local environment, with MAMP and PHP 8.2.4, and I received these two errors:
Deprecated: Creation of dynamic property WA_Include::$End is deprecated in /Users/{user}/Sites/{mywebsite}/webassist/framework/framework.php on line 40
Deprecated: Creation of dynamic property CachedResize_Image::$old_ext is deprecated in /Users/{user}/Sites/{mywebsite}/webassist/caching/CachedResize_Image.php on line 356
Is there a way to update these two files, "framework.php" and "CachedResize_Image.php," with a fix?
Thanks.
I'll attach updated files. They will be included in the next update.
Mike
Thanks! Now it's all compatible with 8.2.
