Session Security
Thread begun 9/23/2009 8:22 am by shaun.andrews | Last modified 9/23/2009 1:35 pm by Eric Mittman | 2234 views | 2 replies |
shaun.andrews
Session Security
I have a question regarding Security Assist and Session Security.
I have Security Assist create Session data from my database on Authentication and I am wondering how 'secure' the Session Data is?
I've been reading a bit about Web Security and Session HiJacking etc.. and as some of the information I am recalling from the database is sensitive I want to be sure there's very little chance of someone to be able to access the data.
Is it safe to use the session start command on pages that you are carying session data over to?
if (!isset($_SESSION)) {
session_start();
Your Feedback would be appreciated,
tom92909Beta Tester
Hi Shaun,
If you're looking for more peace of mind related to privacy, I personally would recommend making all page accesses to your pages utilize a SSL certificate.
Just make sure that all page links go to https://
Your question really relates to the WA extension, but the addition of SSL is an extra element that I would include on your site.
I have looked into this issue a little and in order for a session to be impersonated or hijacked the session identifier would need to be obtained first. From what I have seen and read this vulnerability occurs when using session id's that occur from a get variable. I'm not aware of any of our code that relies on this method for the session variable. So impersonating a session or hijacking it should not be of concern with the code our tools produce. If you have some other info about this or a specific issue associated with this please let us know.
