rsobj.php migration to php 8
Thread began 2/22/2023 6:35 am by Ralph | Last modified 2/22/2023 11:10 am by Ray Borduin | 46 views | 1 replies |
Ralph
Hi folks,
I will be migrating to php 8.x from php 7.4. My pages all work fine in php 7.4, but do not load in 8.x. Is there a new version of rsobj.php or other MySQLi Server Behaviors that might be causing the migration problems?
I have downloaded the latest version of the extensions and have reinstalled - the rsobj.php file is updated to version 2.55 (from v 2.00). This should fix the problem ... I will let you all know after I can test.
Thank you for your advice and guidance.
Yes, that should probably do the trick.
If not, add this to the top of a page:
ini_set("display_errors",1);
That should give you a full error message instead of a blank page that we can use to debug the problem.
