Using Session Variables to create a shopping cart selection system
Thread begun 2/13/2023 7:53 am by yogastudents362523 | Last modified 2/22/2023 11:02 am by Ray Borduin | 2975 views | 7 replies |
yogastudents362523
Hello,
I am having trouble controlling Session Variables.
Your WebAssist Cookies menu item allows me to use the following example code snippet:
@session_start();
if (!isset($_SESSION["TemporaryCart"])) {
$_SESSION["TemporaryCart"] = "".($rsQueryRecordSet->getColumnVal("OnlyOneItem")) ."";
But what I in fact want is the entire array of items in that initial query. But nothing I have tried does this successfully.
I believe, for marketing purposes, that it would be effective if people thinking of purchasing a ticket could preview classes and imagine what they might attend. But I do not want to grant database access to such unpaid and unvetted previewers. It would surely open me up to attacks of all kinds.
I have already created the kind of a "shopping cart experience" I want, and it is already available to my paid ticket holders. But it of course runs by putting their selections into a database. They can browse the entire set of Classes for that day, and then select 4 ... 2 to "livestream", and 2 for later on demand viewing. Those go into the database.
For unpaid people, I thought Session Variables would work better. So I just want to fill a Session Variable with all the classes for that day as extracted from my database. Then previewers can select them from the available items in Session. I can create subarrays of their selections??
But I unfortunately cannot get the results from an initial recordset query into a Session Variable I can manipulate,
I have attached a copy a file that I want to emulate. I also provide credentials for a live version on the server so you can observe what I have done in action if necessary.
I believe that once I get the above code snipper WebAssist Tools provide me working on an entire array, rather than on a single item, I will have the means to select single items from the resulting array, I think I will then be fine with the usual key => variable PHP system.
Thank you for your help.
I don't really understand fully what you want to do. It sounds like you want to save an array in the session, but I don't understand the trigger you want to use or if you are adding one item at a time or multiple. If you provide more background about that then I'm sure I can help.
For instance, if you wanted to save all of the rows in a recordset into a session variable array it would be something like:
@session_start();
$_SESSION["TemporaryCart"] = $rsQueryRecordSet->getColumnArray("ColumnName"));
yogastudents362523
Hello Ray,
Thank you for your response.
I have done more researching. I have found a tutorial. And I now realize that I was asking about something far more complex than I had initially thought. I can well understand why you are not comprehending what I would like to do!!
I am going to work through the underneath tutorials.
https://www.plus2net.com/php_tutorial/array-session.php
https://www.plus2net.com/php_tutorial/array-session-demo.php
If I still cannot figure out what to do, I will hopefully be better informed.
Thank you for your kindness.
I am genuinely wishing you all possible wellness and good health.
I am sorry for the inconvenience.
My sincere gratitude again.
yogastudents362523
Hello,
That tutorial has not helped.
My main issue is how to convert an entire MySQL recordset into a Session Array or Session Variable that is also an associative array giving me access to all data in the original recordset,
I trialled the following code snippet you suggested:
@session_start();
if (!isset($_SESSION["MonclassID"])) {
$_SESSION["Monclassid"] = $ClassesCopy->getColumnArray('ClassID');
The following code snippet:
var_dump($_SESSION["Monclassid"]);
successfully lists the ID for every Monday class, the result being:
array(12) { [0]=> int(2131) [1]=> int(2086) [2]=> int(2093) [3]=> int(2077) [4]=> int(2089) [5]=> int(2065) [6]=> int(2078) [7]=> int(2106) [8]=> int(2102) [9]=> int(2120) [10]=> int(2083) [11]=> int(2109) }
This is of only limited use because the only way I can see to access data such as StartTime, ClassTitle, ClassLength and etc. is the roundabout way of doing for every column what I did for ClassID, which is return to getColumnArray() and create a new and disctinct Session Array just for that.
I then have to carefully correlate all array pointers to ensure I always have the correct data items for each ClassID.
Is there really no way to create a Session Array or Session Variable that is simply an associative array that mirrors a MrSQLi query?
Could I not then simply loop through that Session Array as easily as your tools let me loop through a MySQLi query?
Thank you.
@session_start();
if (!isset(
$_SESSION["Monclassid"] = $ClassesCopy->Results;
That will give you the entire recordset as an array in the session.
yogastudents362523
Hi Ray,
Thank you.
I do not know how I missed you giving me the above. I had just come on to say I had found myGetRow() which I felt I could loop through, but what you have provided is even better.
Ah, the joys of ignorance.
Thank you,
KAB
yogastudents362523
Hello,
When i use:
$_SESSION["AllMonClasses"] = $rsClassesCopy->Results;
to create a Session array; and then use:
var_dump($_SESSION["AllMonClasses"]);
I get the complete listing of data from the orignal database query.
But when I try to access some specific data by for example trying:
var_dump($_SESSION["AllMonClasses"]["ClassID"]);
I get "Null"
And then when I try:
foreach ($_SESSION['AllMonClasses'] as $key => $value) {
echo $key . " " . $value . "<br /><br />";
I get only:
"0 Array
1 Array
2 Array
etc.
I do not get either the keys or the values.
My preference would be a "while loop" that also allowed me to access the individual Sessio Array values through the associative Session Array keys.
I am sorry for the inconvenience. Everything I read says:
should work to access that data, but that does not seem to be the case for me.
How can I access in a controllable way the items in that Session Array?
Thank you.
KAB
yogastudents362523
PLEASE CLOSE
Hello
Please close and ignore this ticket.
I have found another way around this issue.
Thank you
