how to assign table column to a variable
Thread begun 2/09/2023 11:25 am by paulshoe379536 | Last modified 2/12/2023 9:55 am by Ray Borduin | 856 views | 2 replies |
paulshoe379536
I would like to assign a column item to a variable to use in an export file. What's the syntax? The assignment below fails. It works if I only use text instead of $Orders.getColumnVal('OrderID').
$Orders = new WA_MySQLi_RS("Orders",$mydata,10);
$Orders->setQuery("SELECT orders.OrderID, orders.OrderDate, orders.IsGift, orderdetails.DetailName, orderdetails.DetailPrice, orderdetails.DetailQuantity FROM orders INNER JOIN orderdetails ON orders.OrderID = orderdetails.DetailOrderID ORDER BY orderdetails.DetailName ASC");
$Orders->execute();
$OrderID = $Orders.getColumnVal('OrderID');
$OrderDate = "01/22/2024"; //$Orders.getColumnVal('OrderDate');
$testfile = fopen("newfile.csv", "w") or die("Unable to open file!");
$txt = '"'.$OrderID.'","'.$OrderDate.'"';
fwrite($testfile, $txt);
fclose($testfile);
PHP uses arrow syntax not dot syntax for objects, so instead of:
you need:
$Orders->getColumnVal('OrderID');
paulshoe379536
Thanks Ray, that did it. You're always a great help!
