else and elseif statement
Thread begun 2/02/2023 5:38 pm by jo271221 | Last modified 2/04/2023 2:15 pm by Ray Borduin | 651 views | 1 replies |
jo271221
The PHP manual shows ?php only once
if ($a > $b) {
echo "a is bigger than b";
} elseif ($a == $b) {
echo "a is equal to b";
} else {
echo "a is smaller than b";
My rules look more like this - simple working show if
if ($WADAtable->getColumnVal('sire') != '') {
show content here
1) Does the php get repeated?
2) What is the proper format to reference the table and column name
Attempt at show if else which is not even a good attempt.....
if ($WADAtable>getColumnVal("column1") == '') {
1
} elseif {.$WADAtable->getColumnVal("column2") == ''
2
} else { thisrequirement2
3
By adding the extra <?php and ?> you can write content to the page without using echo()
That allows it to be displayed in Dreamweaver design view as well, so I prefer that syntax.
I'm not sure what you are going for with the line:
elseif syntax is exactly the same as if syntax... just it won't run if the code above did. So yours should look more like:
} elseif ($WADAtable->getColumnVal("column2") == '') {.
and this :
should be:
} else (thisrequirement2) {
