"There is an error in your SQL syntax" error. PHP errors on, but no errors showing?
Thread begun 2/02/2023 8:07 am by Nathon Jones Web Design | Last modified 2/04/2023 2:05 pm by Ray Borduin | 784 views | 1 replies |
I'm having trouble with a MySQLi INSERT behaviour. This was working fine on a website, and we've haven't changed anything, so I can only assume that some scripting is out of date but I'm getting "There is an error in your SQL syntax." when submitting the form.
I'd included the following code, in an attempt to view the PHP error that was being generated:
ini_set('display_errors', 1);
ini_set('display_startup_errors', 1);
error_reporting(E_ALL);
...and this mentioned something about curly brackets and an issue with the queryobj.php file, which I replaced with another more up to date version (31/03/2021) of that file.
Since then, I'm still getting the syntax error message, but no details of the php error?
I'm, therefore, completely unable to diagnose what the issue is. Is there anything else I can do?
Thank you.
NJ
You can open up the queryobj.php file and update the line:
$this->Debug = false;
and set it to true.... then it will give you the full error. You should change it back after since errors can sometimes include sensitive information.
