Unexpected closing of DW with data bridge v2, only with asp files
Thread begun 12/11/2022 10:04 am by fabiosaggioro438787 | Last modified 1/09/2023 10:33 am by fabiosaggioro438787 | 1089 views | 4 replies |
fabiosaggioro438787
Hello, after installing Data Bridge v2 it happens that DW closes unexpectedly only when using asp files (not with html or php files). For example, after opening an asp file, if I highlight text or code with the mouse, DW closes. If I do the same thing with the same file but in html version DW stays open.
Please attach a copy of the page that has this issue and I'll try to reproduce it here to see what might be causing it.
fabiosaggioro438787
Good morning,
I attach a sample file and link. The problem seems to occur only when the file also contains asp code as well as html code (no with only html code or html+php). If I change the same file (see attachment) from .asp to .html the problem doesn't exist.
http://www.parrocchiavigodilegnago.it/eventi_news/presepi.asp.
Thank you.
The issue doesn't seem to occur for me. What version of Dreamweaver? I'll probably need to debug this with you with screen sharing in order to determine why it happens. You can call me using the number at the bottom of every page on this website, or contact me via Skype user: webassist.rborduin
fabiosaggioro438787
This post has been deleted.
