Remove delete overlay screen
Thread begun 12/09/2022 10:28 am by eric284736 | Last modified 12/13/2022 10:49 am by Ray Borduin | 596 views | 9 replies |
eric284736
Hi Ray,
I want to remove the overlay screen when you click a delete button and just have that button delete the record immediately without the confirmation screen.
<input type="button" class="formButton ResultsPageButton unstyled DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAGalleryTable['gID']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" />
Is that possible?
Thanks,
Eric
Please attach the page and I'll help. Yes it is possible.
eric284736
Awesome! Here it is.
I think the easiest solution is to update the code found on line 230 from:
onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAGalleryTable['gID']); ?>;WADFP_jQuery('#Delete').click();"
eric284736
updated the code when I click on the delete button nothing happens
There was a missing .js file that was probably removed when you moved your <head> code to an include file. I added it back on line 273 and it seems to work now.
eric284736
Hi Ray,
That works perfectly! I have one more page that does the same thing but I need it to redirect and keep the querystring.
eric284736
pm
On line 157 try updating:
<form class="DetailsPage Basic_Default" id="Results_Basic_Default" name="Results_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<form class="DetailsPage Basic_Default" id="Results_Basic_Default" name="Results_Basic_Default" method="post" action="">
eric284736
Perfect! thanks!
