Send Attachments?
Thread begun 11/06/2022 2:51 pm by yogastudents362523 | Last modified 11/08/2022 9:44 am by Ray Borduin | 833 views | 3 replies |
yogastudents362523
Send Attachments?
Hello,
I am assuming that it is still not possible to send attachments with PowerMessenger (I see no sign of that as an option)?
If not then I doubt I am the first who has asked ... so do you perhaps have a script stashed away somewhere in your archive that uses your standard "SendMail" (ex-Universal Mail) to query the PowerMessenger database, find the appropriate audience, and then send emails plus desired attachment to the specified subscribers?
(Just hoping!!).
I could probably help you implement this if you need it. I don't have a script for it. Give me a call later this week and I can work through this with you.
yogastudents362523
Thank you for your kindness. There are workarounds and I will use those.
Either (a) placing links in the outgoing PM message for recipients to click on so they access the documents on my site; or (b) run a query against the database and copy the resulting addresse to the BCC field of an ordinary mailing plus attachment.
KAB
Yes. Including a link in the body is a perfectly good work around for not being able to add attachments.
