Update record
Thread begun 10/26/2022 9:27 am by birdscreen398247 | Last modified 10/26/2022 10:04 am by Ray Borduin | 739 views | 1 replies |
birdscreen398247
Update record
I have an Update behavior with some If statements in it and it is not working.
Could you take a look at it?
The relevant code is between lines 30 and 72.
I'd have to do screen sharing and debug this in context. I'd start by adding this below line 38:
echo("batch date:". $rsDecisions->getColumnVal("batch_date") . "<br>");
echo("batch date 2:". $rsDecisions->getColumnVal("batch_date2"). "<br>");
echo("ebird date:". $rsDecisions->getColumnVal("ebird_batch_date"). "<br>");
echo("session batch date:". $rsDecisions->getColumnVal("batch_date") . "<br>");
echo("session which:". $_SESSION['batch_date']. "<br>");
echo("ebird date:". $_SESSION["which_batch"]. "<br>");
die();
That will tell you the values of the variables you are using and trying to set to make sure they have the values you expect.
