Random "Fatal error" using views
Thread began 10/15/2022 3:12 am by puppons | Last modified 11/24/2022 11:03 am by Ray Borduin | 78 views | 2 replies |
puppons
I am using the latest version of DataBridge and I am getting "Fatal error" on pages where I created mySqli recordset on views.
The errors I am getting are:
"Fatal error: Uncaught Error: Call to a member function fetch_fields() on bool in /var/www/vhosts/ewineshop.it/httpdocs/webassist/mysqli/rsobj.php:211 Stack trace: #0 /var/www/vhosts/ewineshop.it/httpdocs/index.php(60): WA_MySQLi_RS->execute() #1 {main} thrown in /var/www/vhosts/ewineshop.it/httpdocs/webassist/mysqli/rsobj.php on line 211"
"Fatal error: Uncaught Error: Call to a member function fetch_assoc() on bool in /var/www/vhosts/in-people.it/httpdocs/zoom/meeting_add.php:81 Stack trace: #0 {main} thrown in /var/www/vhosts/in-people.it/httpdocs/zoom/meeting_add.php on line 81"
No errors if I use tables instead of views, but some of them are very complicated and I really need to use views.
If I restart mysql service on my plesk server, then problem is temporally fixed.
Any advice on how to solve this problem?
Thanks, Guido.
I think it will work if you turn off "Prepared Statements" in your rsobj.php file.
Just find this line:
$this->Prepared = true;
and change it to:
$this->Prepared = false;
There is a bug in prepared statements with mySQLi for some versions. If you just turn off that setting it should resolve your issue.
puppons
Thanks!
Turning off "Prepared Statements" did the trick!
Many thanks (and sorry for the late response)
Thanks again, Guido.
