Attaching file
Thread begun 9/18/2022 3:38 am by yogastudents362523 | Last modified 9/20/2022 9:22 am by Ray Borduin | 580 views | 2 replies |
yogastudents362523
Attaching file
Hello,
I have successfully taken people through an on-line contract signing process.
I am successfully sending them an email containing a link to the signed contract.
I am also successfully using File Manipulation to download a copy to my own local computer, for my owjn records.
My preference would be to attach the contract to the email (rather than only providing a link.
However, I cannot find the correct value to put in "Entered Value" of the SendEmail or Universal Email attachments menu.
And I also cannot select the "Submitted File" option in that same menu because no matter what values I put in the Form, that option remains greyed out in Send Email, and so I cannot select it.
Thank you.
I attach the file.
"submitted file" is for when someone has a file upload form field and you attach that file to an email.
Try moving this code above the email code:
$presenters_signature
= $rsAllPresenterData->getColumnVal("PresentersSigningID") ;
$presenters_signature = html_entity_decode(strip_tags($presenters_signature));
$presenters_signature = chop($presenters_signature,"<br />");
// $presenters_signature = substr_replace($presenters_signature ,"",-8) ;
$presenters_sign_url = html_entity_decode($rsAllPresenterData->getColumnVal("PresentersSigningURL")) ;
$presenters_email = $rsAllPresenterData->getColumnVal("EmailAddress1") ;
$presenters_name = $rsAllPresenterData->getColumnVal("Last") . '_' . $rsAllPresenterData->getColumnVal("First");
// $client = new HelloSign\Client($my_api_key); // already instantiated above, before header
// $signatureRequestId = "d196f6c74248650f89a305d1d7eaa26b";
$dest_file_path = $_SERVER['DOCUMENT_ROOT'] . '/presenters/contracts/' ;
$dest_file_name = $presenters_name . '.pdf';
$dest_file_download = $dest_file_path . $dest_file_name ;
$dest_file_download = html_entity_decode(strip_tags($dest_file_download));
$dest_file_download = chop($dest_file_download,"<br />");
// $dest_file_path = substr_replace($dest_file_path ,"",-6) ;
// $client = new HelloSign\Client("fb31abf96d768b94bcd6751d977d1147a81bd7b56643d3444cbc1d54a47d1a93");
// $client->getFiles('21b750a9c435680f8c14d736a2dba09d7259e313', $dest_file_path, HelloSign\SignatureRequest::FILE_TYPE_PDF) ;
$saved_signature_request_id = $rsAllPresenterData->getColumnVal("SignatureRequestID") ;
$client = new HelloSign\Client("$my_api_key");
// $client->getFiles('c49a4555324716dc387b498502a546638d281d03', $dest_file_path, HelloSign\SignatureRequest::FILE_TYPE_PDF) ;
$thisiswhattodownload = $client->getFiles($saved_signature_request_id, $dest_file_download, HelloSign\SignatureRequest::FILE_TYPE_PDF) ;
                  try {
    $result = $client->getFiles('21b750a9c435680f8c14d736a2dba09d7259e313', $dest_file_path, HelloSign\SignatureRequest::FILE_TYPE_PDF) ;
    print_r($result);
} catch (HelloSign\Error $e) {
    $error = $e->getResponseObject();
    echo "Exception when calling HelloSign API: "
        . print_r($error->getError());
$downloadable_file = "https://www.navayogimarga.com/presenters/contracts/" . $dest_file_name ;
$attach_path = "../presenters/contracts/" . $dest_file_name ;
Then you can add the attachment as <?php echo($attach_path); ?>
yogastudents362523
Thank you very much.
That is now working just fine!
With every good wish
KB
