[DB2] multiple dowropdown menu (select)?
Thread begun 8/02/2022 8:13 am by SCar87011738 | Last modified 8/08/2022 10:13 am by Ray Borduin | 1260 views | 4 replies |
SCar87011738
Hello,
I have a form with 3 selects:
1- type
2- brand
3- product
When I select the type (online, offline) select 2 (brand is populated);
When I select the brand (brand1, brand2, brand3) the product select is populated.
I already created a 2 level dependent doropdown, but I have difficulties creatinf a 3 levels dependent dropdown selects.
What is the right approach?
I actually added the 3rd level to the parent page (static-plugin) but I suppose I should add it to the 2nd select (static-plugin child).
Or am I missing something?
UPDATE:
I managed to get something similar to my needs.
The only problem is when, after selecting the third level I change my mind and change the first level.
Actually changing the first select will populate/reset the second select, but not the third select.
How can I make changing the first select resets/repopulate the second and third select?
This kind of a problem was easier to solve in DB1. =(.
Tony
If you attach the page you are working on I can show you how to update the code.
SCar87011738
Here is as private attachment.
TIA
tony
SCar87011738
Hello Ray,
I almost did the job but I can't get to execute any jquery function when the select in the plug-in (inc.pv.php) change.
I published the page on a private area.
You can find the (almost) completed page in the attachment.
What I would like to obtain is that when I select a value from the PRODOTTO select, a jquery function should be run to display a value without reloading the page.
I always do this on flat page (no plug-in) and it always work.
But this time I cannot understand why it doesn't work.
Hope you can help me.
You can find credentials as private attachment.
Sorry to be silly but I'm really in a hurry under the deadline (customer fault).
TIA
tony
SCar87011738
At long last I solved it.
I found the solution on a previous message I posted by myself (!!!): https://www.webassist.com/forums/posts.php?id=44440
Thanks, anyway.
Tony
