Does this still work with the lates dreamweaver?
Thread begun 8/01/2022 1:54 pm by joe159765 | Last modified 8/02/2022 10:49 am by Ray Borduin | 1265 views | 5 replies |
joe159765
Does this still work with the latest dreamweaver?
I am trying to install web assist mysqli for the first time in a few years. I installed dmxzone, it shows as installed, shows that it downloaded files. Has the web assist menu, but the menu does not do anything.
I have done a fresh configuration folder and attempted to install it again. Still same results. Any other suggestions? Thank you.
It should work. It looks like maybe your site definition isn't configured properly.
Go to Window->Server Behaviors and see if that window has any errors. You probably just have to configure your Dreamweaver testing server properly.
joe159765
I'm just seeing it says there are no server behaviors installed.
The installation must have failed. Give me a call and I can look into it with you in a screen sharing session to get everything working properly.
joe159765
This post has been deleted.
