Single Image Upload to resize twice (large image and thumbnail) and write to 2 databa
Thread begun 9/22/2009 7:03 am by Suggs | Last modified 9/23/2009 12:47 pm by Jimmy Wu | 4116 views | 3 replies |
Suggs
Hi Folks,
I need a bit of help trying to do the following:
I want a single image upload field that will resize the uploaded image to a large image size and thumbnail size and write the results to a field called ImageLge and another field called Thumbnail in the database.
Any help would be greatly appreciated.
Cheers
Jimmy Wu
When setting up your upload using Digital File Pro, you will have to specify Web Images Only in the first step and then in the second step, you can change the resize options and other options for one of the images. After you're satisfied with the options, click the "+" button to add another file that gets uploaded to specify the resize and other options. This will upload the same image, but with different resize options.
Suggs
Will this write the image name to 2 different fields in the database?
What im trying to achieve is instead of having 2 File Fields for images to upload, i want to reduce this to 1 File Field and have the image resize to 2 different sizes (which I know how to do), but then write the file name to 2 different fields in the database..
Jimmy Wu
You can access the information for the two files that are uploaded by going to the Bindings panel. Using this information you can upload what you want to your database.
