Enable a user query to see all results if logged in
Thread begun 6/04/2022 4:16 am by Paul | Last modified 6/06/2022 10:47 am by Ray Borduin | 601 views | 1 replies |
PaulBeta Tester
My search result page recordset limits matched results to 1 record by default.
I'm adding security assist access rule to the results page to authenticate a users logged in status with the session value 'uStatus'.
For example, when a user logs in the uStatus session value will be set to 1. (0 if not logged in.)
How would I enable the result page recordset to show all matched records (assuming a query returned 2 or more matched records), if when the uStatus session value is set to 1
Thanks.
You would have to hand code it. If you attach the page in question I can show you in the code, it is hard to explain out of context, but easy to do.
