Using server validation to check SHA1 encrypted password value
Thread begun 5/19/2022 7:18 am by Mags | Last modified 5/20/2022 9:31 am by Ray Borduin | 1531 views | 6 replies |
Mags
Hi Ray, I need to update a user update page so that the user must input their current password in order to update the record. It's failing the validation though - can you see where I'm going wrong? Current code is as follows:
$WAFV_Errors .= WAValidateLE((WA_SHA1Encryption((isset($_POST["password"]))?$_POST["password"]:"")) ."" . "",($SecurityAssistparausers["user_pass"]) . "",true,9);
<input id="password" name="password" type="password" value="">
Maybe the value of $SecurityAssistparausers["user_pass"] isn't set correctly? I'd have to look at the entire page so I can see the code in context.
Mags
I've attached the page for you, many thanks.
Your $SecurityAssistparausers recordset has to be moved above the validation code, since you are using it in the validation.
Mags
Ah, of course! However I moved it and tried again, and it's now giving the following error:
Fatal error: Uncaught Error: Cannot use object of type WA_MySQLi_RS as array in /var/www/xxx/mysite.com/xxx/pagename.php:38 Stack trace: #0 {main} thrown in /var/www/xxx/mysite.com/xxx/pagename.php on line 38. I've attached my updated page.
This is the old recordset syntax:
The new syntax would be:
$SecurityAssistparausers->getColumnVal("user_pass",false)
Mags
Thank you, working now!
