When inserting data as an array, is it possbile to add hyperlinks to each phrase based on show if OR do I need to make a unique column for each item in the array?
Thread begun 5/18/2022 5:55 am by jo271221 | Last modified 5/18/2022 9:46 am by Ray Borduin | 494 views | 1 replies |
jo271221
Also for the existing records that are an array is there a query we can run to put each item into the unique column for the item if we need to go that route.
I'm sure it can be done. Arrays are very powerful and flexible.
Yes, we could write a procedure that breaks an array into separate records.
