There is an error in your SQL syntax.
Thread begun 5/13/2022 8:25 am by birdscreen398247 | Last modified 5/13/2022 9:25 am by Ray Borduin | 721 views | 3 replies |
birdscreen398247
When I click on Submit in the attached file, I get 'There is an error in your SQL syntax.'
Can you see what is wrong?
Open up rsobj.php and queryobj.php and change Debug to true in the settings. That will cause it to give a better error message.
birdscreen398247
Now I get "incorrect INTEGER value."
The only integer is Birder_ID. (Session variable is birder_ID and the table field is Birder_ID)
You reset the session variable based on a posted value that won't exist when the page submits to itself for an update.
You can probably just change line 25 from:
$_SESSION['birder_ID'] = $rsBirders->getColumnVal("Birder_ID");
if (isset($_POST['ListofBirders'])) $_SESSION['birder_ID'] = $rsBirders->getColumnVal("Birder_ID");
