Mail
Thread begun 4/20/2022 10:38 am by birdscreen398247 | Last modified 4/22/2022 8:04 am by Ray Borduin | 1473 views | 5 replies |
birdscreen398247
Mail
In the attached file, BL_user_LifeList_Edit_Form.php, in the section of code from 79 to 117, is the Mail code in the correct place and is the Message line syntax correct?
Maybe you attached the wrong file. I don't see any mail code on those lines.
birdscreen398247
Whoops!
Here is the correct file. Between lines 131-135 and 149-153.
Frank
You would have to move this:
$ExecuteQuery->redirect($ExecuteGoTo);
Below the email code... it would redirect before the email could be sent currently.
birdscreen398247
That worked, but the message arrives blank.
Is this code correct?
$message = "".$_SESSION['member_name']."" & ' has updated their birdlist numbers';
Frank
& should be .
Like:
$message = "".$_SESSION['member_name']."" . ' has updated their birdlist numbers';
