Fatal error: Cannot redeclare class WA_AltClassIterator
Thread begun 4/17/2022 11:27 am by Patrice | Last modified 4/25/2022 10:44 am by Ray Borduin | 2882 views | 19 replies |
PatriceWebAssist
A project worked on a year ago: Client wants to change a component. My attempts for using framework builder is resulting the WA_AltClassIterator error.
See PM for links please.
Since you are including multiple results on the same page you just need to wrap the class definitions referenced in the error with:
if (!class_exists('WA_AltClassIterator')) {
//class definition here
I updated your page and it opens now.
PatriceWebAssist
THANK YOU!
PatriceWebAssist
Sorry... I messed it up. I downloaded the page I thought you changed... familiesTEST, then made changes on pdf_results.php page so I could link to the pdf.
So what you referenced above, what pages was it on? the pdf_results.php page or the family page? Sorry.
PatriceWebAssist
So, if I am guessing right, on pdfs_results.php this code
//WA AltClass Iterator
class WA_AltClassIterator {
var $DisplayIndex;
var $DisplayArray;
function __construct($theDisplayArray = array(1)) {
$this->ClassCounter = 0;
$this->ClassArray = $theDisplayArray;
function getClass($incrementClass) {
if (sizeof($this->ClassArray) == 0) return "";
if ($incrementClass) {
if ($this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter = 0;
$this->ClassCounter++;
if ($this->ClassCounter > 0)
return $this->ClassArray[$this->ClassCounter-1];
else
return $this->ClassArray[0];
should become this??
var $DisplayIndex;
var $DisplayArray;
else
but when trying that red errors are highlighted...
This:
var
$DisplayIndex;
var
$DisplayArray;
function
function
if (
if (
$incrementClass) {
if (
if (
return
else
return
becomes:
var
$DisplayIndex;
var
$DisplayArray;
function
function
if (
if (
$incrementClass) {
if (
if (
return
else
return
PatriceWebAssist
Thank you that worked.
Now I have another issue though. PM
Give me a call tomorrow and we can look at it. I'll have to dig in the code so I think it is easiest to do in a screen sharing session.
PatriceWebAssist
OK... what time is best for you? I am on EST.
PatriceWebAssist
PM
