Discount
Thread begun 9/21/2009 7:59 pm by lbunnell124698 | Last modified 9/22/2009 9:21 am by Jason Byrnes | 1883 views | 1 replies |
lbunnell124698
Discount
I'd like to add a $10.00 discount for session variable == 'xxx', but only when the product ID number is less than 10000. Is this possible using the eCart server behavior 4.1.5?
eCart cannot do a product ID rtange.
You should create a new column in the cart for discountable items. set the value of this column to 1 for items that can recieve the discount and 0 for items that cannot recieve the discount.
When creating the discount rule use the following triggers:
Based on Session Variable Existence:
Is session Variable [<session name>] exists
AND
based on session variable value:
If session Variable [<session name>] has a value [=] to [<xxx>]
AND
number of Products with a specific column value;
If the number of products where [discountable] has a value 0f [1] is [>] a value of [0]
The use the Flat Rate calculation to apply the $10 discount.
