How to create a nested JSON from two different MySQLi query?
Thread begun 4/13/2022 4:20 pm by Rokon | Last modified 4/14/2022 4:54 pm by Ray Borduin | 2762 views | 11 replies |
Rokon
Hello
I was able to create a simple JSON output from the single MySQLi query as below;
die(json_encode($myQuery->Results, JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES));
but now I am in a situation where I need to get output of nested JSON and I can't figure it out where I should put the other MySQLi query so that it can have
output of nested JSON data.
Pls help me to get out from this critical situation. Thanking you.
I'm not quite sure how you want the data.
Do the two recordsets have the same columns?
You could join two recordsets into a single array and then output that as JSON like:
die(json_encode(array($myQuery->Results,$mySecondQuery->Results), JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES));
Rokon
I am attach the file here, I tried but failed and seems I could not figure it out correctly yet, Pls help me.
You already have the hadithsection table in the first query. I think you may be able to delete the second recordset and use your original recordset and just add the SectionBD column to your first recordset.
Rokon
I tried that before but the problem is on the hadithsection table there are many row which have the same book id like a tree. Example Book is the main tree and sections are the branches.
I need to output the JSON as nested like several sections are belongs to one book ID
How are you outputting the json? That seems like something you could handle on the output page that reads in the json. What format do you want the json to have?
I think you would probably have to hand code a loop through the first recordset results so you can get the corresponding rows and then add it to the array so you can json encode it if you wanted to do it on this page.
Rokon
Yes I need to loop the second query result inside the JSON output of first query and in this place I become stuck. To get a view for a regular webpage it is easy for me that I bring the second query inside the 1st query repeat region and I can get the result what I want but to get a JSON output for the both query like nested I failed.
Can you pls guide me a bit here so that I can try.
<?php require_once('../Connections/hadithbd.php'); ?>
require_once('../webassist/mysqli/rsobj.php'); ?>
$hadithBooksList
= new WA_MySQLi_RS("hadithBooksList",$hadithbd,0);
$hadithBooksList->setQuery("SELECT hadithbook.BookID, hadithbook.totalHadith, hadithbook.BookNameBD, Count(hadithsection.BookID) AS totalSection FROM hadithbook LEFT OUTER JOIN hadithsection ON hadithbook.BookID = hadithsection.BookID WHERE hadithbook.Active = 1 GROUP BY hadithsection.BookID ORDER BY hadithbook.priority ASC");
$hadithBooksList->execute();
while (!$hadithBooksList->atEnd()) {
$sectionList
= new WA_MySQLi_RS("sectionList",$hadithbd,0);
$sectionList->setQuery("SELECT hadithsection.SectionBD FROM hadithsection WHERE hadithsection.BookID = ?");
$sectionList->bindParam("i", "".($hadithBooksList->getColumnVal("BookID"))  ."", "-1"); //WAQB_Param1
$sectionList->execute();
  $hadithBooksList
->Results[$hadithBooksList->Index]["Sections"] = $sectionList->Results;
$hadithBooksList->moveNext();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Generate Hadith Books JSON File</title>
</head>
    <body>
header
("Content-Type: application/json; charset=UTF-8");
die(
json_encode($hadithBooksList->Results, JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES));
</body>
</html>
Rokon
$hadithBooksList
$sectionList
  $hadithBooksList
<!doctype html>
<html>
<head>
</head>
    <body>
header
die(
</body>
</html>
Exactly what I was look for, Thanks a lot Ray for you great great support!
Rokon
$hadithBooksList
$sectionList
  $hadithBooksList
<!doctype html>
<html>
<head>
</head>
    <body>
header
die(
</body>
</html>
Just a little more of your kind support further needed please. I am trying to just include the "chapterList" query under the "sectionList" query for one more step nested JSON. Please give me one more final push here to overcome the whole things. Thanks a lot Ray!
$hadithBooksList
$sectionList
$sectionList->setQuery("SELECT hadithsection.SectionID, hadithsection.SectionBD FROM hadithsection WHERE hadithsection.BookID = ? ORDER BY hadithsection.SectionID ASC");
$chapterList
= new WA_MySQLi_RS("chapterList",$hadithbd,0);
$chapterList->setQuery("SELECT hadithchapter.SectionID, hadithchapter.ChapterBG, hadithchapter.ChapterAR, hadithchapter.ChapterEN FROM hadithchapter WHERE hadithchapter.StatusActive = 1 AND hadithchapter.BookID = ? AND hadithchapter.SectionID = ? ORDER BY hadithchapter.chapID ASC");
$chapterList->bindParam("i", "".($hadithBooksList->getColumnVal("BookID"))  ."", "-1"); //WAQB_Param1
$chapterList->bindParam("i", "".($sectionList->getColumnVal("SectionID"))  ."", "-1"); //WAQB_Param2
$chapterList->execute();
  $hadithBooksList
header
$json = json_encode($hadithBooksList->Results, JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES);
//die(json_encode($hadithBooksList->Results, JSON_UNESCAPED_UNICODE|JSON_UNESCAPED_SLASHES));
file_put_contents("hadith_books_section_chapter.json", $json);
