Select Field
Thread begun 4/12/2022 10:11 am by birdscreen398247 | Last modified 4/12/2022 11:58 am by Ray Borduin | 557 views | 1 replies |
birdscreen398247
Select Field
In the following code, when I make a selection, it doesn't display it in the select box. It just keeps showing the"Select County" text.
How do I make it show what I selected?
<select name="CountyName" id="CountyName" onchange="this.form.submit()" >
<option value="" selected>Select County</option>
while(!$rsCounty->atEnd()) { //dyn select
<option value="<?php echo($rsCounty->getColumnVal("CountyName")); ?>"<?php if (!(strcmp($rsCounty->getColumnVal("CountyName"), ((isset($_GET["select"]))?$_GET["select"]:"")))) {echo "selected=\"selected\"";} ?>><?php echo($rsCounty->getColumnVal("CountyName")); ?></option>
$rsCounty->moveNext();
} //dyn select
$rsCounty->moveFirst();
</select>
That is because it submits the form when you change the selection and that causes the page to refresh. I think it might work if you update the references of: $_GET["select"] to: $_GET["CountyName"]
Or it might need to be: $_POST["CountyName"]
(if your form action is method="post")
