Can I show a file upload field on an update form if no file already exists?
Thread begun 4/05/2022 2:44 pm by art226587 | Last modified 4/26/2022 2:39 pm by Ray Borduin | 3147 views | 10 replies |
art226587
I have an insert form that contains 3 file upload fields. The user doesn't always upload all three files, but I would like them to be able to go back and upload them afterward using the update form. I'm clueless how to a) check if the file exists and b) display the file upload field if it doesn't. Here is the HTML for the update.php form:
<div class="lineGroup"> <label for="file1" class="sublabel" > file 1:</label>
<input name="file1" type="file" id="file1" size="30" tabindex="32" title="Please enter a value.">
</div>
<div class="lineGroup"> <label for="file2" class="sublabel" > file 2:</label>
<input name="file2" type="file" id="file2" size="30" tabindex="33" title="Please enter a value.">
</div>
<div class="lineGroup"> <label for="file3" class="sublabel" > file 3:</label>
<input name="file3" type="file" id="file3" size="30" tabindex="34" title="Please enter a value.">
</div>
Here's what's in my details.php page to display the files for downloading:
<tr>
<td class="DetailsSublabel">File 1</td>
<td class="DetailsPage"><a href="upload/<?php echo($WADAmrf_2021_details->getColumnVal("file1")); ?>"><?php echo($WADAmrf_2021_details->getColumnVal("file1")); ?></a></td>
</tr>
<tr>
<td class="DetailsSublabel">File 2</td>
<td class="DetailsPage"><a href="upload/<?php echo($WADAmrf_2021_details->getColumnVal("file2")); ?>"><?php echo($WADAmrf_2021_details->getColumnVal("file2")); ?></a></td>
</tr>
<tr>
<td class="DetailsSublabel">File 3</td>
<td class="DetailsPage"><a href="upload/<?php echo($WADAmrf_2021_details->getColumnVal("file3")); ?>"><?php echo($WADAmrf_2021_details->getColumnVal("file3")); ?></a></td>
</tr>
Basically, I'd like the link to the file if a file exists and a form field if no file exists. Alternately, it would be nice to be able to delete an existing file and upload a new on from the update.php page.
Is this nuts? Thanks!
This would only show the row if there is a file specified in the database:
if ($WADAmrf_2021_details->getColumnVal("file1")) {
<tr>
</tr>
art226587
Thanks, Ray. So, that part shows the file link if one exists, but the code below will display the form field regardless:
<div class="lineGroup"> <label for="file1" class="sublabel" > RFP File 1</label>
<a href="upload/<?php echo($WADAmrf_2021_update->getColumnVal("file1")); ?>"><?php echo($WADAmrf_2021_update->getColumnVal("file1")); ?></a>
<input name="file1" type="file" id="file1" size="30" tabindex="17" title="Please enter a value.">
</div>
How would I make this an either/or that only shows one or the other?
} else {
</div>
art226587
That worked great! Last question: Is there a way to allow the user to delete an existing file? It doesn't necessarily need to delete it from the file system as well. I just want a way for them to upload a newer version of the existing file if desired. This could be a multi-step process, like checking a "Delete" checkbox next to the file, clicking Submit and then updating the file again to upload a new one.
Yes. You can have an upload option on an update page. You can use whatever process you want. A checkbox would work, or just have the input field and let them know that if they specify a new file it will be replaced.
art226587
Ah, I see. So, if I pass a new value to that field, it will simply replace what's in the db. And just display a new upload field via a link or button with an onClick and some CSS. The "delete" part is not as clear. I think I can wrap my head around using js to pass a value to a hidden form field, but I don't know enough php/SQL to know how to empty from the db. Any pointers?
I think a checkbox to delete is probably the easiest option. Then you can check if the box was checked and clear out the field if it was with a simple IF statement. If you create the page and attach it to a reply, then I could show you where to make the change for deleting. Make sure you have everything else working before posting the file.
art226587
Thanks, file attached!
You can add the checkbox and then change the DefaultFileName values to clear out the value if the checkbox is checked. So, for example, line 46 might become:
'DefaultFileName' => "".(isset($_POST["deleteCheck1"])?"":$WADAmrf_2021_update->getColumnVal("file1",false)) ."",
