Can not make the login page work
Thread begun 3/23/2022 9:30 am by msmoose2400634 | Last modified 4/11/2022 12:53 pm by Ray Borduin | 3351 views | 18 replies |
msmoose2400634
I have worked on this for a week and I can't get it to work properly; first the following "code (ass="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="">) appears as a text as you will see in the screen shot and secondly when I enter my username and password and bothing happens. Here is the site http://mussolinetestserver.site/login11.php
msmoose2400634
Originally Said By: msmoose2400634
The code from lies304-314 should have been added to the <head>.
I'm not sure how it got that way, but I think you can just copy and paste it to get it to the right place. Then you should be left with:
<form class="Basic_Default" id...
msmoose2400634
Unfortunately still not working; but however I am back to my orginal problem, can't connect to the database. The database panel, whenever I click on any of the icons, plus sign, pencil, etc nothing happens. I uninstalled the webassist extension, site options===> remove previous connections and still nothing happens. Karen
msmoose2400634
Here is the updated login11.php (see attached); also for some reason this is what I see in the url bar when i test the page: http://127.0.0.1:56513/preview/app/index.html (instead of the http://mussolinetestserver.site/login11.php)
On line 311 you have:
<form cl
It should be:
<form class="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="">
Try updating that so your form tag is complete and that should help.
msmoose2400634
I did fix line 311 and I don't show any errors or unnecessary text but when I login it says invalid... I have texted you the username and password int he private message. Plus I have attached the .php page
Can I get FTP access and a url to test live?
Try removing this line (106):
$Authenticate->addFilter("persSeq", "=", "i", "".($rs_allMembers->getColumnVal("persSeq")) ."");
I'm not sure your intention for this line, but it means simply having the username and password correct, wouldn't necessary allow you to log in.
msmoose2400634
Hi Ray, I did remove he line 106; I did not add the line; it must have been generated by the "Create Security Pages" function. I also don't understand the two lines following the line you asked me to remove:
$Authenticate->addFilter("username", "=", "s", "".((isset($_POST["Log_In_group_Username"]))?$_POST["Log_In_group_Username"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["Log_In_group_2_Password"]))?
The form still does not workl; when I put my username and password it still says invalid
On line 11 you have a password length restriction with a minimum of 6 characters.
You can update that to 2 or 4, or just delete that line.
