Repeat Selection and Insert Multiple Records Solution
Thread begun 3/23/2022 8:12 am by s.joiner74419001 | Last modified 3/24/2022 1:49 pm by Ray Borduin | 1390 views | 4 replies |
s.joiner74419001
I have a section of a form that gives information on Flat / Apartment blocks if there is more than one block. There is an input field that firstly asks how many blocks at the property. This value can be between 2 and 8.
html:
<input type="number" class="form-control" id="blocks" name="blocks”>
I would like to use this value as the dynamic value for a repeat selection below it. The repeat selection will have two input fields repeated: 'Block name' and 'Block Numbering'. So for example if the input field above has the number 4. The two fields in the repeat selection will be repeated 4 times.
See attached screen shot to see how it looks using a static value of 8 for the repetitions ( 8 is the maximum accepted )
<div role="group" class="row block-details" area-labelledby="block-label">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_None){
<div class="col-md-6">
<div class="form-group row">
<label for="blockName1" id="block1-label" class="sr-only">Block 1 name</label>
<div class="col-lg-6 col-xl-7">
<input class="form-control name" name="block_name_1" id="blockName1" placeholder="Name of block 1" >
</div>
<label for="blockNumbering1" id="numbering1-label" class="sr-only">Block 1 numbering</label>
<div class="col-lg-6 col-xl-5">
<input type="text" class="form-control" name="block_numbering_1" id="blockNumbering1" placeholder="block 1 Numbering i.e 1-9'" required="" >
</div>
</div>
</div>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_None && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_None = mysql_fetch_assoc($None);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</div>
My problem is when I change the ‘repetitions value to a dynamic value using the ‘blocks’ input’ .. It doesn’t work.
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 0;
$RepeatSelectionCounterBasedLooping_1 true;
$RepeatSelectionCounter_1_Iterations "".((isset($_POST["blocks"]))?$_POST["blocks"]:"")  ."";
What’s wrong here?
Plus is it possible to create placeholders dynamically so they are numbered correctly for the amount of repeats.
(Page attached)
Thanks in advance!
I think you are mixing client and server code. The fieids are on the same page... are you expecting the number of rows to update as you update the field? That would have to be done with javascript, not php.
If you had the blocks field on the previous page that submitted to this page, then the code would work.
s.joiner74419001
Thanks Ray.. Yeah i'm getting mixed up. I'll have a re-think. Cheers!
This is something I could help with in a premier ticket if you want. It may be difficult to pull off without some custom code, but shouldn't take too long for someone that can write javascript to duplicate the rows in the browser.
s.joiner74419001
I've managed a workaround for now similar to the setup on the current site which will do for now. I'll more than likely get your help under a support ticket as I will also have other work Ill need your help with which is integrating Stripe into our e-cart setup. I'll message you on a new post regarding that.
If it works better to keep these separate then thats fine just let me know!
