Validate a Form with WebAssist
Thread begun 3/21/2022 7:58 am by Brunco53 | Last modified 3/22/2022 9:07 am by Ray Borduin | 620 views | 2 replies |
Brunco53
Hello
I want to validate a form with WebAssist.
With JQuery Validation I have selected the desired fields.
As requested, a display prompt comes up to enter the unfilled field.
After filling in, the submit button is missing.
Further, at the select field no prompt appears, although this dropdown field was also marked as required.
Can you help me further?
Here is a video with my problem....
https://www.screencast.com/t/T7D25xYPHpDK
You must have other code on the page that is causing the form button to disappear. This is relatively common in some scripts to prevent someone from clicking a button twice and double-submitting a form. You would either have to remove that code, or add a check to make sure the form is valid before hiding the button. This isn't webassist code, so I'd need a copy of the page to debug and determine where and how the code is initiated.
Since it is client-side code, I would just need a live URL to see the page and debug it.
Brunco53
Hello, Thanks for the tip, I am trying to determine the error.
I will contact you if I need help.
With kind regards
brUNO
