Multi-Step form set-up
Thread begun 3/21/2022 7:28 am by s.joiner74419001 | Last modified 3/23/2022 10:40 am by Ray Borduin | 1146 views | 4 replies |
s.joiner74419001
I have an Application Form which I have split into 4 sections so I can display the process in 4 steps. I have put each section in its own form, all on the same page. So the way I want this to work is each time the user submits a section they are advanced to the next step. I have been trying to set this up using session variables. When the page loads. the value for a session variable named 'formStep'is set to 1. Step 1 of the form has a 'show region utility' round it which shows if the session formStep is equal to 1. I thought that each time the user clicks the next ( submit ) button I could trigger a session variable and set it to 2. and show Step 2 which has the 'show region utility for the same value. But the when the submit button is clicked it doesn't appear to update the session value.
Am I trying to achieve my multi-step form correctly?
Hope this makes sense.
Thanks in advance.
That sounds like a possible solution. If you attach a copy of the page you are working on, I might be able to spot the flaw in your logic.
s.joiner74419001
So I have the session vraiable triggered before page load with the value of '1'. I have the first form in a show behaviour:
html:
if ("".$_SESSION['formStep'] ."" == "1") { // WebAssist Show If
....Form Markup
} // ("".$_SESSION['formStep'] ."" == "1")
This works fine. So I then re-set the session when the form submits:
html:
@session_start();
if(isset($_POST["submit_pcd"]) || isset($_POST["submit_pcd_x"])) {
$_SESSION["formStep"] = "2";
But this doesn't seem to work. Is this wrong?
page attached!
After your insert, the page redirects back to itself... that causes the session variable to be reset. I think it will work if you change the trigger on the initial session variable set code from:
@session_start();
if(
$_SESSION["formStep"] = "1";
@session_start();
if(!isset(
$_SESSION["formStep"]))     {
s.joiner74419001
That works .. thanks Ray
