Insert query
Thread begun 3/09/2022 6:21 am by birdscreen398247 | Last modified 3/09/2022 1:20 pm by Ray Borduin | 974 views | 3 replies |
birdscreen398247
Insert query
I want an insert query to run only if the record doesn't already exist.
In the attached file, the insert query starts at line 135. The relevant field is record_number (which is a key field).
I have a recordset at line 65 that looks for a record with that number (nit sure if this is a way to do it).
So, if a record already exists with a matching record_number, then don't do the insert.
Right now, I am getting a "There is an error in SQL syntax" error message, which I think is from this insert query because of the conflicting key values.
How do I do this?
You could wrap your insert code in:
if ($rsDecisions->TotalRows == 0) {
// insert code here
That way it won't run if the recordset checking for duplicates has a record in it.
birdscreen398247
I had the GoTo page in the Insert Query.
Since the insert query is now conditional, I put it in the Form Action property instead.
Now the update query doesn't update.
Where can I put this so both the update and insert queries work (when conditions are met)?
Move the goto to the Update and then move the insert above the update.
