Show a success notification on database update
Thread begun 3/08/2022 9:56 am by Paul | Last modified 3/09/2022 10:30 am by Ray Borduin | 2367 views | 7 replies |
PaulBeta Tester
I have a DA update page which reloads after the update button pressed.
What WA tool is best to hide a success notification until the record is updated, when it is enabled visible?
I'd add a url parameter to the page when a successful update takes place and use that to show the message on update.
You can use the Server Behavior->WebAssist->Utilities->Show Region Utility to only display when the url parameter is present.
PaulBeta Tester
Thanks, pursued this route
I'm using a url param idx to pass the record id to the update page
Now on my update page, the recordset has errored on the line marked in red
$rsCGIUpdate = new WA_MySQLi_RS("rsCGIUpdate",$cgiDB,0);
$rsCGIUpdate->setQuery("SELECT * FROM cgi-mnc-data WHERE idx = ?");
$rsCGIUpdate->bindParam("i", "".$_GET['idx'] ."", "-1"); //colname
$rsCGIUpdate->execute();
What am i missing here?
Is the idx value in the url properly? If you add:
ini_set("display_errors",1);
To the top of the page, it might show you the actual error.
PaulBeta Tester
Am puzzled, as idx is parsing the value ok and it bringing back all the mapped record data
When i go to save, im getting an Undefined index: idx
For some reason when i update it doesnt like idx as its reporting undefined
What is your form action? Can you send a copy of the page?
PaulBeta Tester
<form enctype="multipart/form-data" class="m-auto" name="cgimodify" style="max-width:600px" method="post" action="modify-cgi.php">
Change it to action="" and the url parameter will automatically forward in the submit.
