Fatal error: Uncaught mysqli_sql_exception: Commands out of sync
Thread begun 3/07/2022 5:18 am by georgina_barrett_187762 | Last modified 3/09/2022 10:33 am by Ray Borduin | 7542 views | 3 replies |
I built a content manager for a website and then copied it to another website.
Everything seems to work ok when I test it through Dreamweaver. The recordsets all seem to work and the insert/update scripts all connect to the database and seem to work. The problem comes when i try and view the files online I am getting this error:
Fatal error: Uncaught mysqli_sql_exception: Commands out of sync; you can't run this command now in /home/mywebsite/public_html/webassist/mysqli/rsobj.php(587) : eval()'d code:1 Stack trace: #0 /home/mywebsite/public_html/webassist/mysqli/rsobj.php(587) : eval()'d code(1): mysqli_stmt_store_result() #1 /home/mywebsite/public_html/webassist/mysqli/rsobj.php(587): eval() #2 /home/mywebsite/public_html/webassist/mysqli/rsobj.php(235): WA_MySQLi_RS->waMySQLiResultFetchAssoc() #3 /home/mywebsite/public_html/manager/Client_ID.php(24): WA_MySQLi_RS->execute() #4 {main} thrown in /home/mywebsite/public_html/webassist/mysqli/rsobj.php(587) : eval()'d code on line 1
**UPDATE**
I can see what is causing the problem, but I don't know why.
This recordset works fine:
$Recordset1 = new WA_MySQLi_RS("Recordset1",$connect_i,0);
$Recordset1->setQuery("SELECT * FROM customercontacts");
$Recordset1->execute();
But this recordset throws that error:
$Recordset1->setQuery("SELECT * FROM customercontacts WHERE customercontacts.RefID=?");
$Recordset1->bindParam("i", "".((isset($_GET["ID"]))?$_GET["ID"]:"") ."", "-1"); //colname
It seems to throw the error when you have a variable.
Could it have something to do with the hosting? I normally use a different provider (and have never had this problem) but I am using 123-reg to host this site
Is customercontacts a table or a view in the database?
Maybe try opening the rsobj.php file and turn off prepared statements. Let me know if that makes a difference.
Thank you!
customercontacts is a table.
I turned off prepared statements in the rsobj.php file (for anyone else looking how to do this change line 27 to - $this->Prepared = false;)
and it worked!
I am a designer and don't really understand too much coding - what does this mean? Will it effect anything by doing this?
There is a bug in one version of php and or mysqli that causes prepared statements to not work properly. Prepared statements uses built in mysql functionality to prevent SQL injection. When you turn it off, it uses a webassist version of SQL Injection protection in its place.
It really shouldn't make a difference. In fact the recordset should run a little faster.
