I am trying to display the members picture, name and date of birth in a recordset. I can display the name of the picture in the recordset but I can not display the actual picture. See more below.
Thread begun 3/01/2022 5:43 pm by msmoose2400634 | Last modified 3/18/2022 1:22 pm by Ray Borduin | 3934 views | 29 replies |
msmoose2400634
Basically what I am trying to do is display the picture of the member with their date of birth and their picture. Thank you!
I have a recordset that has 3 fields, member name, avartar ( varchar100, that holds the picture name of the member, and the perseq (primary field) I also have a folder membersPage/avartar/thumbnails (that holds the actual picture and the name of the picture); when I create a table to display the picture name and the member's name everything works fine, but I want to display the actual picture and not the picture name. I tried using the File Manipulation but I am unsucessful.
You probably just need something like:
<img  src="membersPage/avatar/thumbnails/<?php echo($rs_birthdays->getColumnVal("avartar ")); ?>">
msmoose2400634
Didn't work (sad)
I changed the code as you suggested and I get an image icon for the recordset but not the actual picture itself. I also tried the File Maniuplation as I thought this is where I would download the picture and I get an error message (you will see it in the attachment.
I tried it both ways as well:
<td><img src="/membersPage/avatar/thumbnails/<?php echo($rs_birthdays->getColumnVal("avartar ")); ?>">
<td><img src="membersPage/avatar/thumbnails/<?php echo($rs_birthdays->getColumnVal("avartar ")); ?>">
msmoose2400634
oops I did put the closing </td> just forgot to put it in the previous post to you, sorry
It looks like your column name may have a typo try:
<td><img src="/membersPage/avatar/thumbnails/<?php echo($rs_birthdays->getColumnVal("avatar",false)); ?>"></td>
msmoose2400634
I copied and paste your code and I still get the same results, the image does not appear but just a broken image icon. I have attached a document and circled on the property for the ima scr property and it shows a broken image icon, is that showing me an error. And I really appreciate your time and efforts to help me (as I am rewritting all my websites because I used Dreamweaver CS3 and the Developer's toolkit so this is somewhat of a big learning curve for me). Do you know of a tutorial for webassist on how to download a dynamic image from a recordset so I can try to understand the process instead of reaching out to you all of the time).
I also circled the image icon on the birthday list so you can see what is being displayed.
Can you attach the .php page and include a url where I can see the problem? Are you sure the column name is correct? Are you sure the database has a valid image name?
msmoose2400634
I have attached the .php page and I also attached a screen image that displays the person's image name, the image icon and on the far right is the remote server avatar directory that shows the image name, I wanted to make sure that the person's image name under the birthday list is also in the membersPage/avatar directory, which it is. http://testkaren.site/home1.php my working website that I am trying to rewrite is www.OldUnionWGA.com and you can see how the birthday image is suppose to display.
Thank you
It looks like the images are showing now. Did you find the solution? One of them has a missing image, so you probably just need an IF statement to show an image not found image instead.
msmoose2400634
Yes I am sorry I thought I replied that I found my error, here is the correct path. You had it right but I didn't catch the silly quote mark.
<td><img src="membersPage/avatar/<?php echo($rs_birthdays->getColumnVal("avartar")); ?>" width="50" height="50"> </td>
I needed to put the php statement inside the quotes. And yes you are right I will need an IF statement for those who do not have a picture.
But now I have a worst problem, but I am trying to work around it before I reach out to you (oops i guess I am reaching out to you). It is so strange. The home1.php shows my mysql recordsets under the binding panel, but when I either refresh or click the plus sign to add the database it gives me this error message. "No tables found. Please check your connection. Which is strange because I haven't changed anything. I attached the screen shot.
