sql grouping and display
Thread begun 2/23/2022 10:08 am by birdscreen398247 | Last modified 2/23/2022 1:37 pm by Ray Borduin | 553 views | 1 replies |
birdscreen398247
I have a query which I display as seen in attachment ListDisplay1.pdf.
I want to display it like ListDisplay2.pdf. Ie. Break the list on each county name, list results for that county, then another county name and so on.
The page in question is BL_Annual_County_OneBirder.php
I know how to do this in MSAccess with grouping and sorting, but can't figure it out in sql/php.
Any suggestions?
The easiest solution is probably to use two recordsets. One with the counties... then repeat region to show all of the counties. Then move the second recordset into the repeat region and filter it with the current county. Then repeat on the second recordset to show the individual records.
