Did something change with CMS? I can't get into CMS on any of my sites.
Thread begun 2/20/2022 6:05 pm by LWag48648773 | Last modified 2/23/2022 1:09 pm by Ray Borduin | 1258 views | 4 replies |
LWag48648773
The sites work but no content is on the page. The page content below the CMS include does not load so I know it is that code causing the problem. And I can't login to CMS on any of my sites. HELP! I have towns/villages relying on this content.
Thank you!
It appears you have an issue with your server and mysqli not being installed properly. You will have to open a support ticket with them to debug it.
I created a test page you can show them to help them see the issue. It has the code:
ini_set
("display_errors",1);
echo(
function_exists("mysqli_init")?"mysqli is working now":"mysqli is not installed");
$PowerCMSConnection = mysqli_init();
If you show them that page, they should be able to fix it for you.
LWag48648773
Thanks so much for all the help Ray. Unfortunately, GoDaddy thinks it's not their server. We did look at another site. I'll put that login info in private message. You can look at the error log there.
Same exact issue on those other sites. I knew they would deflect blame ;)
Call them back and then do a 3-way call and include me. I won't let them try to avoid blame.
LWag48648773
You were right Ray! All sites working again. The mysqli module on the server quit working. Not sure why the first guy couldn't see that. It was listed as a known issue.
Thanks so much for your time even when it wasn't your issue.
