Discounts in cart code one time instead of for each ID possible ?
Thread begun 2/10/2022 8:14 am by lr_leal239405 | Last modified 8/23/2022 2:56 pm by Ray Borduin | 6384 views | 24 replies |
lr_leal239405
For each items in our database of products, I have to add the code to apply the discount for the specific ID of the product. Is there a way to not have to do it for each one? instead have the discount apply to all that share a common trait..For example any that starts with 'WB-' ?
If not, is there to automatically add the code below with the ID when a product is added to our database (simultaneously)? (in the file eCart1_PHP.php)
//eCart Rule
function WAEC_eCart1_QuantityDiscount646() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "ID", "4190") >= 6) && ($this->ConditionalTotal("Quantity", "ID", "4190") <= 10))) {
$totalDiscount += (floatval($this->GetInfo("4190", "TotalPrice")) * 0.05);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
function WAEC_eCart1_QuantityDiscount647() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "ID", "4190") >= 11) && ($this->ConditionalTotal("Quantity", "ID", "4190") <= 20))) {
$totalDiscount += (floatval($this->GetInfo("4190", "TotalPrice")) * 0.1);//Result
//eCart Rule
function WAEC_eCart1_QuantityDiscount648() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "ID", "4190") >= 21))) {
$totalDiscount += (floatval($this->GetInfo("4190", "TotalPrice")) * 0.15);//Result
Maybe you can give me an idea on what to do. Thank you.
lr_leal239405
Actually, I just thought of adding an include file with that same code that would be placed at the bottom of the last one in the eCart1_PHP.php file. Then have that file updated automatically with that code, when a product is entered into the shopping cart database - and just grabbing the ID and replacing it in the right places. Do you think that's an alright idea? Or maybe you know a better way. Thanks.
lr_leal239405
Actually the numbers have to be figured out and written as well:
WAEC_eCart1_QuantityDiscount645
etc.
and this line as well:
$this->Discounts[] = new WA_eCart_Rule(urldecode("QuantityDiscount648"), true, "WAEC_eCart1_QuantityDiscount648");
So, it's a little more involved although I think doable.
I think you might be able to do it more easily by adding columns to your products table like:
DiscountMin1
DiscountAmount1
and
DiscountMin2
DiscouneAmount2
and
DiscountMin3
DiscountAmount3
Then add all 6 of those to the cart columns as well. Then your rules can be written to be based entirely on a cart column and not depend on productIDs at all.
Then add a calculated column for:
QuantityDiscount = (([Quantity]>[DiscountMin1])?[Price]*[DiscountAmount1]:0) + (([Quantity]>[DiscountMin2])?[Price]*[DiscountAmount2]:0) + (([Quantity]>[DiscountMin3])?[Price]*[DiscountAmount3]:0)
Then add a few more calculated columns:
NewPrice = [Price]-[QuantityDiscount]
RowDiscount = [QuantityDiscount] * [Quantity]
Then you could update the TotalPrice calculation to be: [NewPrice] * [Quantity]
and then you wouldn't even need to add a discount rule at all since it would be included in the cart.
Of course you could also keep the TotalPrice calculation as it is and use a discount rule instead. It would just be set as a discount equal to the sum of the RowDiscount column.
lr_leal239405
You're probably right, but for now, I've already added the auto inserting function which inserts into two separate (for rule and for function). It actually has been working. However, I can't 'include()" the file under the rules functions (below)...
//eCart Rule
function WAEC_eCart1_QuantityDiscount1022() {
$totalDiscount = 0;
if (true && ($this->ConditionalTotal("Quantity", "ID", "4910") >= 21)) {
$totalDiscount += (floatval($this->GetInfo("4910", "TotalPrice")) * 0.15);//Result
BECAUSE, it says 'unexpected include....'. Do you know how I can use the "include' the file under that?
So, I've been just been copying and pasting them. These are auto inserted when a salesperson writes a quote which happens a handful of times every day, so I have to copy once a day (before the client places the order (adds to cart with quantity changed) from an Auto Quote (electronic quote).
Thanks.
try using require() instead of include()
lr_leal239405
I get the same:
syntax error, unexpected require(T_REQUIRE)
Please attach the page. There may be another syntax error on the page causing this issue.
lr_leal239405
ok. here it is
I don't see the reference to include() or require() in that file. What is the error that I'm looking for? I may need to see and debug this one live. Can you give me a url to demonstrate the issue and provide FTP access for me to debug it?
