Creating a recordset using a value from an existing recordset value
Thread begun 2/02/2022 12:43 pm by Paul | Last modified 2/02/2022 4:24 pm by Ray Borduin | 904 views | 3 replies |
PaulBeta Tester
I have a products page populated from a recordset 'rsDevInfo' using $_GET to acquire the record ID.
In the same page I want to use the value <?php echo($rsDevInfo->getColumnVal("Manufacturer")); ?> derived from 'rsDevInfo' in a new recordset where all values in my OEM columns match it.
So basically, if my current page is returning 'Sony' in the rsDevInfo recordset, I want to create another recordset showing me only those records which match 'Sony'.
I've tried a $_GET hack in a second recordset ... but doesnt return anything!
$rsRelated = new WA_MySQLi_RS("rsRelated",$MyDevDB,1);
$rsRelated->setQuery("SELECT devices.*, oems.Manufacturer FROM devices INNER JOIN oems ON devices.ProductOEM = oems.ID WHERE devices.ProductOEM=?");
$rsRelated->bindParam("i", "".$_GET['($rsDevInfo->getColumnVal("Manufacturer"))'] ."", "-1"); //oemid
$rsRelated->execute();
any thoughts?
You have your parameter set to "i" which means integer. If you are passing in a value like 'Sony' you would want to use 's' for string instead.
You would also need to make sure that the $rsDevInfo recordset is above the $rsRelated recordset in the code and that it is returning the value you expect.
PaulBeta Tester
Thank you.
I'm using numerical values for the OEM column in my Product table which maps to an OEM record in my OEM table, so the 'i' parameter is fit for this purpose. I've also positioned the recordsets accordingly.
i'm not convinced $_GET is pulling the OEM record from rsDevInfo recordset as my second recordset isnt returning any values.
I've changed
to
$rsRelated->bindParam("i", "".$_GET['$rsDevInfo->getColumnVal("ProductOEM")'] ."", "-1");
I'm using ProductOEM from my 1st recordset DevInfo as the (integer) variable in my second recordset rsRelated.
Can you confirm i'm using the correct syntax for the above? I've tried removing the parenthesis.
I really don't know what you are doing, so I can't comment on what is correct out of context.
$_GET is used for variables passed in the url. I think you might actually just want:
$rsRelated->bindParam("i", "".($rsDevInfo->getColumnVal("Manufacturer")) ."", "-1"); //oemid
