Adding multiple database records from a form using a repeat region
Thread begun 1/31/2022 1:49 pm by Mags | Last modified 2/01/2022 10:06 am by Ray Borduin | 848 views | 2 replies |
Mags
Hi Ray, I have an event registration form which uses a repeat region to display events with checkboxes so that the user can register for multiple events. Currently the form entries are written to the database in a single entry with the events logged in one column i.e. "Event 1<br>Event 2<br>" etc. I would prefer to have one row added per event checked which would make it easier to search for attendees at a particular event. I've updated the page with a multiple Insert behavior but it isn't adding anything to the database. I've attached a copy of the page - can you see what I've done wrong?
With the latest MySQLi Server Behaviors you don't have to use a multiple insert to get that working. Remove the multiple insert and use a standard insert and when you bind the event column use the (array) version from the bindings and it should do the multiple insert automatically.
Mags
Great thanks, worked no problem at all!
