Limit data in a recordset?
Thread begun 1/25/2022 3:26 am by john70964 | Last modified 1/27/2022 9:15 am by Ray Borduin | 1346 views | 6 replies |
john70964
Hi Ray
Is there any way to limit the length of data in a recordset.
For example
If I wish to use only 150 characters of a field containing more, can this be done with a recordset?
John
You can do that with php using the substr() function: https://www.php.net/manual/en/function.substr.php
john70964
Thanks Ray,
That's an amazing site and an amazing subject, beyond my pay grade.........
I suppose there are no less complicated solutions you know of?
It's really quite simple... instead of:
$Recordstet->getColumnVal("column")
use:
substr($Recordstet->getColumnVal("column"),0,150)
john70964
Hi Ray
I seem to have this working partly <?php echo(substr($rsTitle->getColumnVal("Description1"),0,150)); ?>"> but I am still seeing text well over the 150 setting.
I wondered if I have the above code correct?
I have attached the file.
John
That should work... Do you have a URL and FTP access I can use to see the issue?
john70964
Hi Ray
I found my mistake, I had included an extra field in my selections from the recordset.
Sorry to have bothered you.
John
