MySQLi apostrophe inconsistency
Thread begun 1/21/2022 1:00 pm by yogastudents362523 | Last modified 1/21/2022 2:43 pm by Ray Borduin | 883 views | 2 replies |
yogastudents362523
Hello,
I generated this query which worked just fine:
$rsAllPresenterData = new WA_MySQLi_RS("rsAllPresenterData",$mysqli_navayogimarga,1);
$rsAllPresenterData->setQuery("SELECT * FROM presenter_data WHERE ID = ?");
$rsAllPresenterData->bindParam("i", "".(isset($_SESSION['SecurityAssist_ID'])?$_SESSION['SecurityAssist_ID']:"") ."", "-1"); //colname
$rsAllPresenterData->execute();
Please notice the single quotes around SecurityAssistID.
I then generated this query, which simply would not work:
$rsCreateCode = new WA_MySQLi_RS("rsCreateCode",$mysqli_navayogimarga,0);
$rsCreateCode->setQuery("SELECT ID, `Last`, `First` FROM presenter_data WHERE ID = ?");
$rsCreateCode->bindParam("i", "".(isset($_SESSION['SecurityAssist_ID'])?$_SESSION['SecurityAssist_ID']:"") ."", "-1"); //colname
$rsCreateCode->execute();
Again notice the single quotes.
And then I suddenly remembered that MySQLi has on a previous occasion generated an SQL query in which it had used straight quotes instead of backquotes `, in a MySQL query upon the database.
So I tried substituting backquotes for those single quotes and that still did not work.
HOWEVER, I eventually substituted double quotes to give me:
$rsCreateCode->bindParam("i", "".(isset($_SESSION["SecurityAssist_ID"])?$_SESSION["SecurityAssist_ID"]:"") ."", "-1"); //colname
and that is now working like a charm, and allowing me to proceed.
Is there some logical rhyme and reason why MySQLi dodges around amongst these different quotes, because I then experimented with all qypes of quotes in both the direct MySQL queries and within the MySQLi statements, and I can't make a bit of sense of the variability.
It is a little disturbing, when you don't have that much confidence in your coding abilities, to be thrown off course by such a little eventuality, and it would help a lot if I knew that the difficulty might be in these generated scripts, because I spent an absolute age trying to figure out what I was doing wrong, only to have everything working when I changed those quotes. So it would be kind of nice to know what's up, if you are aware of why.
Thank you for your kindness,
KAB
Single and double quotes are interchangeable in php.
In MySQL you need single quotes usually for strings.
The slanted quotes in mySQL are encapsulation characters for columns that have restricted words in them... like First and Last in yours since those are also the name of mySQL functions.
yogastudents362523
Thank you.
That kind of makes sense ... ... ... except that ... ... ... it was the quotes around SecurityAssistID that I changed.
I didn't touch the others at all.
So I shall just assume that when there are 'function words' or 'reserved terms' of any kind in a query, then it makes a difference to all quotes used in that query. And I shall systematically examine and if necessary change them all.
It would of course be far better to avoid those function words, which I guess means becoming more invinventive in my choice of names.
Thank you again.
