I have a search page and results page. There is a search working on the results page however the search page is not adding the &Search=Search and not returning results,
Thread begun 1/20/2022 10:19 pm by jo271221 | Last modified 1/31/2022 9:11 am by Ray Borduin | 1665 views | 6 replies |
jo271221
More details in PM
You probably just have to add properties to your button like: name="Search" value="Search"
so that it gets included in the url.
jo271221
That solved it. Thank you. Now for the page displaying the results where I want the PV listings to display by default and the search results when searched. I put the specifics in the private message on the original posted and also posted comments on the page to make it easier.
Thanks again!
You can add a default where clause to the search server behavior to return the results you want when no search is performed.
horse-products-services-breeders.php?Search=Search
Would then return the default search results only.
jo271221
OK, sounds simple enough but I do not know how to do that. I am pasting my search codes in the PM section.
Thank you!
Open up the search server behavior. Where it says "Default where clause" put in the where clause you want to return the records that will display by default when an empty search is performed.
jo271221
This was resolved in a meeting and we were able to show specific results based on no search, search with 0 results and successful search.
Thank you!
