conditional updating
Thread begun 1/10/2022 8:32 am by birdscreen398247 | Last modified 1/11/2022 1:34 pm by Ray Borduin | 2078 views | 5 replies |
birdscreen398247
I have a form with two fields tied to the same table field.
One is a display of the current value, the other is a dropdown list to select a new value.
On the form, only one of those fields is displayed based on the content of the table field.
In the update query, I want to designate which form field to bind based on the same criteria I use to display those fields.
Lets say the table name is PORC_dates and the field is date1 and the two form fields in question are datepicker1 and currentdate1.
If PORC_dates.date1 already has data in it, I don't want to update it at all. But if it has no data, then update it from datepicker1.
Is that possible?
Everything is possible. It sounds like you would need a few IF statements. It might be easier to set a variable above the insert code to get the value you want updated. If you attach the page you are working on I could take a look and give you sample code. It is a bit too complex to talk about generally and expect you to implement it.
birdscreen398247
See attached file.
I want to update PORC_decisions.batch_date depending on the following.
If PORC_decisions.batch_date already has a date in it, do nothing.
If PORC_decisions.batch_date is blank, update it from the form-select-field "batchdate."
I think you can just update line 27 to:
$UpdateQuery->bindColumn("batch_date", "t", "".($rsBatchDates->getColumnVal("Batch_Date")?"":$_POST["batch_date"]) ."", "WA_IGNORE");
birdscreen398247
When I run that code, I get "there is an error in your SQL"
I have since changed the code to"
$UpdateQuery->bindColumn("batch_date", "t", "".($rsDecisions->getColumnVal("batch_date")?"":$_POST["batch_date"]) ."", "WA_IGNORE");
As the field to check is $rsDecisions->getColumnVal("batch_date"") rather than the rsBatch_dates one.
Now when I submit, it just goes to a blank page (without updating).
Is the rsDecisions recordset code above the Update code? If you attach the page I can see the code and answer your questions more efficiently.
