Building DataAssist pages crashes Dreamweaver
Thread begun 12/29/2021 7:25 pm by DeanCollins | Last modified 12/31/2021 9:38 am by Ray Borduin | 2942 views | 7 replies |
DeanCollins
Dreamweaver 21.2; DataBridge 2.3.5; MySQi Server Behaviors 1.08
I've deleted the WinFileCache, and I've uninstalled and reinstalled the extensions.
When I try to generate DataAssist pages, I get the following errors then Dreamweaver crashes:
1. While executing ... the following JavaScript error(s) occurred: In file "file ... MM.WASiteToolsProcessingObjectV2" has no properties
2. error occurred: In DA updateProgramPanel: Type Error: document.getElementById ("fullProgress") has no properties
(The second error appears twice.)
I'll have to do screen sharing with you to debug this. I just reinstalled and tested and I'm not seeing that error.
DeanCollins
Okay. How? I have Zoom.
If you post your phone number in the private area, I will give you a call and we can work through what is going on.
DeanCollins
See private message.
We ended up having to delete the user's configuration folder and do a clean install in order to correct this issue.
DeanCollins
Update: When I reinstalled the Design Extender extension, the errors returned. So, I uninstalled Design Extender and Data Bridge, then reinstalled Data Bridge and now it's working again. (It wasn't enough to just uninstall Design Extender, had to do both because there were all sorts of errors until I did.) Maybe after another Dreamweaver upgrade or two, I'll try to get Design Extender back.
Try installing Design Extender first if you do and that might work. Design Extender hasn't been updated for MySQLi yet.
