trouble populating input box
Thread begun 12/29/2021 6:58 pm by yogastudents362523 | Last modified 12/30/2021 4:12 pm by Ray Borduin | 2575 views | 9 replies |
yogastudents362523
Hello,
I can now get data input into the HTML editor input box to be stored in the database.
Before I disappear down a rabbit hold and try to code the "obvious" from scratch, is there some simple way to:
(a) get the input box to load up with any current data stored in the database (e.g. for further review/editing) when a user first logs in (for a new session)?
(b) placing any updated versions immediately back into the input box so people can simply continue editing?
Both can be done in PowerMessenger, and it seems so obvious that I fear I have missed some checkbox or similar to allow this.
Where might I find the code for these two events, and before I struggle with jury-rigging something myself?
Thank you,
KAB
(If you want to see the specific page, I will put it in the upcoming private area in the reply to this).
yogastudents362523
I have put the URL to the page concerned in the private area.
yogastudents362523
OK I eventually had a go.
I tried the underneath code snippet.
It first of all told me that there was an error in the SQL syntax, so I recreated everything.
And once I had done that, there was no effect at all; I was just left with the initial value showing in the input box.
Thank you.
URLs you need are in private area..
if ($rsAllPresenterData->getColumnVal("Biography"))
$CKEditor_initialValue = $rsAllPresenterData->getColumnVal("Biography");
else
$CKEditor_initialValue = "Please place your Biography here.";
You had a few issues on the page that I've corrected.
You needed an "update" button on the page to submit the form. Your update trigger had to be changed to use that form submission, and some of your bindings were set to the recordset, which doesn't make sense since it was updating to the existing value.
Finally I updated the default value of the html editor to come from the recordset if it has a value and put in the enter value message if it is blank.
Please download the file so you can see the changes.
yogastudents362523
Hi
Thank you.
I have several other places I need to get data through the HTML editor, so I will study this very closely.
I have a backup copy both on the server, and here locally.
I am, as ever, very grateful.
Thanks again,
KAB
yogastudents362523
Hello,
ISSUE (1):
I put in some test data. This is literally what is showing upon the page:
"Let's now try <strong>putting this in</strong>, in order to see what happens.<br /> <br /> Thanks.<br /> <br />"
I.e. editor is displaying almost literally what is in the databse, reading back precisely the coding I am assuming it is taking in (from the editor).
I tested by using the "View Source" button built-in to the edite, and I then got:
"Let's now try &lt;strong&gt;putting this in&lt;/strong&gt;, in order to see what happens.&lt;br /&gt; &lt;br /&gt; Thanks.&lt;br /&gt; &lt;br /&gt; &nbsp;"
ISSUE (2)
I am uncertain of the protocol as regards the Update button you have provided, and the Save button within the body of the editor.
When should I use which one?
(Granted that I will have to give instructions to my clientele).
Thank you.
Thank you,
KAB
I've updated the trigger in the update record server behavior so that both buttons will work. (you can remove one or the other if you want)
I've also updated the value so that it will display html properly.
yogastudents362523
Hi Thank you. The bolded (strong) text is now displaying correctly, but not the line breaks:
Let's now try putting this in, in order to see what happens.<br /> <br /> Thanks.<br /> <br />
Source code being:
Let's now try <strong>putting this in</strong>, in order to see what happens.&lt;br /&gt; &lt;br /&gt; Thanks.&lt;br /&gt; &lt;br /&gt; &nbsp;
Thanks,
KAB
That might be leftover from when it wasn't working. Please clear it out and try again.
yogastudents362523
Thank you, that seems to have been corrected.
I will play around with it for a little while, and hopefully there will be no other issues.
I am immensely grateful.
Gathering such data is essential to my entire project.
KAB
